Hardline tubing
That is right, i have gone for the 10/12 EK route and absolutely love it. You can get away with sharper bends if you are careful. No need for the monsoon kit if you want to save dosh, my first 6/7 builds used the edge of the table.
I've used 12/16 in my build, should finish it tomorrow. I find 12/10 would be too thin for me. You can get a kit off OCUK that comes with all the tools required including heat gun, silicone insert' bending mandrels, saw, cutting block, deburring tool aswell as a selection of 150-300mm rules.
If you do get one don't forget adapter as my heatgun came with EU 2 pin. Had to cut it off and wire in a new plug myself as I didn't have an adapter.
