- 13 Feb 2009
- London
Hi lads.
should i take that plastic prong out on the hardrive. ? as it says it limits to 1.5 Gb/s Operation. But shouldn't be 3 Gb/s Operation. ?
Also, i'm installing 2 hardrives. one for XP, the other for Vista64.
Would it be ok to use the same connectors from the PSU to the 2 hardrives, or doe's it have to be 2 seprate ones ? they won't lose any kind of power would they ?
Cheers.
Cheers.
