- 9 May 2010
- sheffield
Hey all,
So upon decorating our 3rd bedroom we have dicoverd the plaster is a mess and about 30% is blown.
I have taken off the loose stuff and left the good bits, I have bought gypsum hardwall as the base and multi finish to skim.
My question is do i need to pva the edges of the existing good plaster to help the bond between new (hardwall) and old, or can i just slap on the hardwall and not worry?
If i can get the hang of it I may plan to skim the entire room , in which case should i pva the remaining walls not including the hardwall prio to skim?
Hope this makes sense.
Thanks
GM
Thanks
GM
