I am currently thinking about changing my current set up in a few subtle ways. I cant afford a huge upgrade but I think I can afford a tweak here and there. Here is my system as it stands.
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156)
Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz
MSI GeForce GTX 460 HAWK "Super-OC" 1024MB GDDR5 PCI-Express Graphics Card
Sapphire Pure 625W Modular Power Supply
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler
Windows 7 (64bit)
Xtreme gamer XiFi sound card
Also worth nothing that this is all wrapped up in a green chieftec dragon case.
So, here are some of the changes I was thinking about doing.
1) I am thinking about making more room in my case by replacing my cpu cooler with one of these http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-CS&groupid=701&catid=57&subcat=2262. The main reason is because of the reduction in noise that I would receive and space I would suddenly find myself with. At the moment the Arctic cpu cooler I have takes up just over 2 ram slows which makes a ram upgrade impossible. Would this be a wise move?
2) With the new space gained from changing the cpu cooler I now have 2 ram slows I can do something with. So I am thinking about putting another 4gb in to bump it upto 8gb. Trouble is that sort of ram isn’t available anymore. What would be a suitable replacement?
3) I brought the ram, mobo and cpu as an overclocked bundle from here and hand on heart I have no idea how its overclocked or how to even investigate how it is overclocked. If I change the ram does this suddenly affect the overclock?
4) I am thinking about changing the graphics card. Its not that the 460 is a bad card its just that I have to under clock it slightly (its an oc model!) to make sure it doesn’t ctd so I would rather just start with something new and better. I was thinking about this http://www.overclockers.co.uk/showproduct.php?prodid=GX-176-EA&groupid=701&catid=1914&subcat=2255. I know its pricy but it seems like a lot of bang for buck. Although should I wait for the 670 models?
5) Also I am thinking about changing my case to this.. http://www.overclockers.co.uk/showproduct.php?prodid=CA-018-LN&groupid=701&catid=7&subcat=1447. Mainly for space but I reckon this case must have better airflow along with a better chance to swap the case fans for much quieter ones.
Sorry if this whole topic seems a bit vague but essentially I am just looking for some solid advice on what to do next. My budget is about £600 but ultimately the cheaper I can upgrade for the better.
Thanks in advance for any advice or tips.
Happy bank holiday
Tonytank
Windows 7 (64bit)
Happy bank holiday
Tonytank
