Hey folks, I’m in dire straights here and I’m hoping you can help me out a little.. or at least confirm my suspicions.
We have an A8R32-MVP Deluxe which seems to have died a death tonight. Installed Windows Vista on Friday and everything has been working fine and reliably since then.
However tonight while playing World of Warcraft it just suddenly decided to die. Giving a BIOS checksum error and then gave me the option to restore the BIOS from a floppy/CD/USB Device.
So I download the BIOS from ASUS and pop it onto a CD, pop it in the drive and boot up… the BIOS recovery tool seems to delete the existing bios and the program a new one followed by a prompt to restart the machine to recover.
‘Cool’ I think.. ‘this wasn’t so bad’ .. how wrong was I? .. after shutting down and then powering the machine back up again.. I’m confronted with the same issue. BIOS checksum etc. I try to recover the BIOS multiple times from the CD to no avail.. every time it fails.
I was kinda clutching at straws now so decided to clear existing BIOS data by removing the battery and moving the jumper to clear the BIOS. After resetting the jumper and replacing the battery I now get nothing on screen at all.
It’s quite bizarre.. everything seems to be connected properly, all the fans are spinning and the CD-ROM spins like it normally would during post but there is just nothing being displayed.
I must say I’ve totally drawn a blank on what the problem could be other than a hardware fault with the BIOS chip or something similar.
Do you think (from the limited information I have given) that the machine is recoverable from here? .. or is it basically an RMA job? How possible is it to get a new BIOS chip to replace the old one if that is indeed the fault?
Any info and help you have give will be a real bonus folks… as all I really have here at the moment is a quite large and rather expensive paper weight.
