- 6 Feb 2008
I have no idea what the fault is so want sure what subsection to put it in.
I am getting a crash where the system will just freeze and i get a weird stuttering noise for a while and the screen will also black, and went cream the other day and few minutes later i will either get a BSOD or have to restart the computer.
This only ever happens really in games after about 5/10 minutes of gameplay. First instance i thought it was the graphic card as when the pc did freeze then unfroze i would get a "Display driver atikmdag stopped responding and has successfully recovered." in the event viewer so reported the fault to OcUK they requsted an RMA too find that the product had not faults and passed all the tests.
Ran Memtest for 6 hours and that came back with no errors, Ran prime on my overclock for 18hours that was fine and have even but my CPU back to stock now but still the crash happens.
I ran HD tune pro and get
Ran HD Tune pro and in the health monitor i have status: Warning
(C7) Ultra DMA CRC Error count
Current: 200
Worst:200
Threshold:0
Data: 2066
Description: Number of interface communication errors: 2066
Status: There were communication errors. This may be caused by a damaged cable.
Also after the crashes occur and a look at the event viewer i have the error
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected. Service Control Manager Eventlog Provider
and other errors like
The following boot-start or system-start driver(s) failed to load:
i8042prt. WMI
or
Unable to initialize the security package Kerberos for server side authentication. The data field contains the error number. HttpEvent
and
416: ERROR: read_msg errno 10054 (An existing connection was forcibly closed by the remote host.) Bonjour Service
Any help or suggestions would be greatly aprreciated
Thanks
Current: 200
Worst:200
Threshold:0
Data: 2066
i8042prt. WMI
or
and
Thanks
