Hardware for Home Lab
18 Oct 2002
Nr Colchester, Essex
What are you guys running for home test labs?
I want to look at various things I don't have admin access to at work (Exchange, SCCM, Higher Level AD stuff) as well as Vsphere, Hyper-V and newer versions of Windows Server and anything else I don't get hands on with.
I am thinking 2 physical servers with a separate storage solution, to be able to test out various VM scenarios and Vsphere features.
Therefore I think the options are something like 3 MicroServers, running 2 with a hypervisor and 1 as shared storage, FreeNas, ReadyNas or the Synology emulatory thing. However you can pick up 1U servers with 2 x Quad Low Power Xeon's and 8-16gb for about £120 shipped. So maybe 2 of those + a Microserver.
Will the Microservers cut the mustard do you think? I would guess they will have better resale value than Dell or HP 1U servers but the Xeons will be a lot faster.
What do you think?
The HP microservers can run 3-4 VMs per host if they're not too CPU intensive. I have 4 connected to a Dell 2950 running openfiler as iSCSI storage.
The other option is to buy a higher spec single host and nest the installation as VMware now has vmtools for nested VMs.
MW
If you plan on running FreeNAS virtualized it will have to be ESXi and Hyper-V doesn't support BSD as a guest. I'd also avoid never mentioning that you are visualising it if you go anywhere near the FreeNAS forums as they will be less than helpful.
I can however say that it does run and work exactly as intended under ESXi as mine has been running for 9 months now without a hitch.
