Hi All,
I am about to build a machine to install the above software to run my vm's.
I would like to make sure i have this running on a decent machine. Currently I have an old machine that I am wondering if can handle the job perhaps with an upgrade of ram.
Specs are -
Pentium DC E5300
4 gig ram
Gigabyte eq45m-s2 motherboard
I guess if that spec isn't compatible then perhaps a cpu upgrade would be possible?
Other options I have looked at are either a 2nd hand hp ml110/115 g5 or perhaps a newer g6.
What would you recommend as the best course of action?
Specs are -
Pentium DC E5300
4 gig ram
