Hardware powering Question.
12 Jul 2010
i have this motherboard P7P55D Pro.
Full res image: http://www.productwiki.com/upload/images/asus_p7p55d_pro_1.jpg
As you can see i have 2*4 pin & a 3 pin Fan powering sockets. (the 3pin PWR can't be used)
i wish to use 2 viper fans, 2 general case fans & a antec 620 cpu cooler(pump).
i wish to connect each viper to a 4 pin socket to enable pwm.
The question part.
The general case fans require a 3 pin socket each so will a splitter survice?
http://www.overclockers.co.uk/showproduct.php?prodid=CB-013-AK&groupid=1929&catid=153&subcat=
For the 620 pump also requires 3 pins, will a molex to 3 pin converter work? no real point connecting a steady pump to a motherboard?
http://www.overclockers.co.uk/showproduct.php?prodid=CB-012-AK&groupid=1929&catid=153&subcat=
Thanks
