About a week ago my PC developed an issue. Crashing to desktop in Battlefield 6 (I hadn't tried other games at this point). The crash resulted in the D: drive becoming unavailable (physically) after the crash. The only fix is to power the machine off and bring it back - at which point it was fine. The PC has been running flawlessly for about 18 months. I thought, OK - perhaps it is a bad NVME drive (controller fault or something). Every event log messages were around stornvme (id 129), stornvme (11)m, disk (51), Ntfs (50), Ntfs (130). I scanned the drive (long scan in the samsungs magician software) and no errors showed up - drive diagnostics showed no issues either.
I figured I'd do some obligatory stuff such as updating the motherboard BIOS to latest, swapping GPU drivers / clean install of, windows updates, re-install the game and anti cheat software. Same crash almost instantly to within a few minutes of the game playing. Weirdly I did get a 40 minute session between those without issue. I tried the Finals and that was fine but then other games like red dead redemption 2 and GTA Enhanced also bombed out. Eventually all games became unplayable whilst my system remained OK overall (after a hard power down and back on).
Next up was moving the games to the other nvme.... same issue. So, two drives both both dying if a game is started. Next I changed my BIOS settings to optimised defaults to rule out any memory timing issues. Same problem again! I see no other errors at all other than nvme related ones. This leads me to think that it could be my Motherboard or CPU? If it were CPU I'd expect to see more problems...
Currently running an OCCT memory test which is looking fine so far. Stability has been rock solid since I built it. Anyway, I have ordered another motherboard since my Asus one has some warranty left on it and it gives me something to rule out. Be keen to see what you guys think?
I can re-produce the failure at will by launching a game so something is unhealthy!
Cheers
Cheers
