Hi,
recently my computer would crash and wehn it rebooted the screen would be weird liek static all over it kind of thing and it wouldnt boot windows unless putino safe mode, the onyl way of fixing this was to format and then reinstall windows and it was fine.
it happened again a few days ago and now nothing appears on th emonitor it just says check signal cable.
Ive eliminted the monitor and cable as the problem as they both work when hooked into my laptop, now im thinking its eitehr the gfx card or he mobo? but the thing is when i formatted and reinstalled it wokre dfine so mebes its a software issue im not to sure.
Ive got no way of testing the gfx card or mobo
Any ideas?
computer is fairly old like
Msi K8n Neo platinum
Geforce 6800gt 256b
1gb corsair xms 3200
Amd 64 3000
Any ideas?
Geforce 6800gt 256b
Amd 64 3000
