For the past few months i have been having trouble getting my PC to startup. Its a relatively new pc (this year) and works quite well once it is on, but it still encounters problems even then.
Firstly turning it on:
If i shutdown or reboot my pc it wont come back on. Everything appears to be starting up but the monitor stays black.
If i power it off though (keeping my session stored) it comes on most of the time, though this is not always the case.
Usually there is no beeps, but on rare occassions i will try turning it on and i will get 1 long beep followed by 1 short beep. Apparently this means its a DRAM error but seeing as i usually get no beeps i have a feeling it is a faulty motherboard.
Secondly once it is on:
It usually works absolutely fine, i can even run Crysis on the highest settings with no problem at all. But recently i have been having a few problems when playing games.
I have mostly been playing Left 4 Dead recently, and i will sometimes get white blocks followed by thin blue lines at the top half of the screen. Then my game will freeze and the monitor will go black. I tried pressing my graphics card up (probably not a good idea) and everything went back to normal and i continued playing with no problems.
At first i thought it was just this game, but today i decided to play Thief 2 and when i got to the menu those pesky blue lines showed up. I loaded a game and the same thing happened! So now im thinking perhaps i have graphics card problem or a faulty motherboard? I mean this game is pretty old, there MUST be something wrong if i cant even run this game properly.
So to summarise, i am having trouble getting the pc to startup and when it does occassionally i get blue lines and it freezes.
Any ideas? Oh and im a hardware n00b so please use dumbspeak cause im really awful with technical jargon even if it sounds simple to you.
Here is some system specs too:
4GB RAM
ATI HD 4870 Video card
Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Abit IP35 Pro Motherboard
4GB RAM
Any ideas?
