- 24 Dec 2007
I recently upgraded my RC of windows 7 to Pro 64 bit and started having an issue.
I have 4GB of memory installed in my system, however I actually only apparently have access to 1791MB of it:
As you can see, my 1024MB 4800 is being given an extra 600 or so memory, and I'm thinking perhaps it's counting that twice since I have 2 monitors plugged into it and thus using an extra 1200MB of memory (which would account for the missing 1GB from what I would usually be getting.) Is this the cause?
I tried to re-overclock my computer and ended up using defaults on the bios of my IP35 Pro, I'm wondering if anyone who has experience with this mobo knows if there is a setting somewhere which would account for the additional hardware reserved memory (Which didn't exist before I don't believe) or if it is something else which is causing this.
Also, the memory usage you see on task manager there is from the desktop, with only stuff like antivirus, firefox and msn being used. Is there a reason over 65% of my memory is being used (even at 1791MB max) when the computer is idle on desktop?
