Hardware scan fail
2 Jul 2021
United Kingdom
Hi all, I think there’s a problem with the Lenovo hardware scan option. On my V15 the time changes to 00:00 very quickly and then goes back to the correct time and then passes fully.
With my Legion 5i Pro the time changes to 00:00 and gets stuck on the test and then pops up with an error Webview and goes to a white screen.
The thing is, a friend of mine has bought a brand new Legion 5i Pro and has the same problem with the hardware scan. Is anyone else having similar problems?
Also, after restarting my PC the time went back to normal and the BIOS has the correct time, but every time I or my friend runs the test the above happens.
I have reset my PC before and had it checked over hardware wise in a shop and it’s fine. Do I need to reset my laptop again after running the test ?
