Hello,
I have a problem with my GigaByte Z97X-Gaming 7 motherboard. The ethernet socket is not working. When trying to connect it shows the connection as limited. I also noticed it can disable all other devices connected to the router until I reboot the router again (sort of like a short circuit).
I have tried the same router, same ethernet cable on my macbook and it connects just fine so it is clearly a problem with either the motherboard socket (hardware fault) or drivers (software fault). I am trying to diagnose this but have hit a wall with it so I am hoping someone here can help.
The last thing I want to do is have to replace the motherboard as it is a newly built PC. Everything else on the motherboard and PC is working just fine and the AO(All Okay) code shows on the motherboard.
I have the latest drivers installed. The socket worked for about a week on the newly built PC but its now been a couple of months and hasn't worked since. I have been connected wirelessly since but wish to connect through ethernet again.
