I've been having a few very strange issues with my current rig and I'm really not sure as to the root of the problem. I'll start with my rig:
Core 2 Duo 6300
Asus P5B Deluxe
Nvidia 7600GT
2GB Corsair XMS2 5400 (2x1GB)
Tagen 430W PSU
Now the rig ran just fine for the first few months but then I started getting lots of random crashes and general instability. This problem was tracked down to a huge number of errors in memtest, however both memory sticks tested fine individually in any slot, and failed catastrophically together in any slot layout. At the time I created a thread on this issue here. In the end I didn't find a solution and just made do with only using one stick.
After this I hadn't had any problems at all until this morning. I have 2 identical seagate 7200.10 200GB drives, one with an XP install on it and the other with a Vista install. My computer crashed and restarted, and when the bios loaded I noticed the Vista drive had disappeared. I've checked all the cabling and its all fine. I tried adjusting the jumpers on the back (the options are limit operation to 1.5Gb/s or 3Gb/s) and the first time I did this the drive re-appeared in the bios but then disappeared again once I exited the bios to load windows. Since then no amount of fiddling with the jumpers, cables or sata ports has got this drive back.
To add insult to injury my XP install seems to be dead now as well. Having given up on the Vista drive I tried loading up XP but was greeted by a blue-screen and restart. Now I get the option screen for choosing "last known good configuration, safe mode, etc" but on selection of any of these options it just freezes until I restart.
I'm feeling frustrated to say the least, and out of ideas. Could it be a faulty motherboard that's caused all this? The memory issue seems to suggest that, could it also have caused the death of my hard drives? I was also thinking it could be the power supply but it should be enough to run my rig, shouldn't it? I aslo find it weird the Vista drive briefly reappeared only to vanish again.
Thanks for reading all this, anyone got any ideas?
Core 2 Duo 6300
Asus P5B Deluxe
Nvidia 7600GT
Tagen 430W PSU
