So how advanced are the harmony remotes now, please educate me.
These are a couple of screen shots of the app you can get to remotely control a humax box from a tablet via wifi (just touch tablets screen to control)
can you do this with harmony ?
[ I suppose - do harmony sell a networked ir emitter with app ... if not they are soon going out of business
maybe someone also built one with raspberry pi
OK a harmony is more robust/child-proof ]
I think you are missing the point of having the remote, it controls all your devices at same time and takes away the need for the other remotes.
Example, I press the TIVO option on the remote touch screen, it turns on the TV, the virgin box, the sound bar and sets the TV to the right HDMI input. All done with 1 button press from 1 remote, not the 3 I had to use previously.
I then press the Media Server option on the remote touch screen, it turns the TIVO box off, changes the TV channel and turns the HTPC on from standby.
The off button just turns everything off that was on, again all 1 remote but you get the idea by now no doubt
The remote has an online database of no end of devices you can program it for and set it up exactly how you want. It is a great piece of kit to be fair.
