Man of Honour
- 8 Nov 2007
- Outer Space
Hi guys,
Seem to have a potential problem?
I was in the process of fitting my new XSPC AM4 Raystorm Neo CPU block but at the very first point of fitting the long screws into the motherboard back plate (which it also says to use a nylon washer) it doesn't seem right to me?
The back plate is still loose & wobbly, not fixed tight like I've come to expect from other CPU cooler installs? So I've not gone any further until I can find more information, which seems non-existant so far?
So is this normal and will it tighten up once I've screwed in the CPU block etc??
Thanks
Thanks
