heatsink clips could be interesting . . . so would clearances id imagine lol.
yes, the reason i ask is, that you wouldn't need to run it at full speed.... because it will probably be cooler than a standard fan at only 1/2 speed
195CFM and add 63dBA to the noise profile ...but at half speed maybe 97 CFM and 31.5 DB...
just an idea![]()
dBA isn't linearHalf of 63dBA is 53dBA (ish)
oh well, that rules out the Delta then
they've got a new one at 252 CFM and 5500rpm.... lol
Not necessarily, half the speed is still half the perceived soundStill ~50DB tho is hella loud. I'd look at Noctuas / Apaches / Gentle Typhoons tho
195CFM and add 63dBA to the noise profile ...but at half speed maybe 97 CFM and 31.5 DB...this setup wont need push/pull, because its air pressure is so high................just an idea![]()
dont put a delta on a fan controller
just a warning
[unless your propertly is insured for fire damage]
