Has anyone used a G-Sync monitor with a GTX 690 ?
Man of Honour
21 May 2012
Dalek flagship
The reason I ask this is G-Sync users are reporting microstutter with SLI. What is interesting is the GTX 690 has a hardware solution to microstutter and so in theory should not suffer with the problem.
Having said that though is a GTX 690 compatible with G-Sync or is it too old.
Never tried it Kaap, but the 690 should work with gsync. I've used a 650ti with the Rog swift.
The bit I am interested in is does the 690 work without the microstutter problems reported with other NVidia SLI setups.
It isn't really stutter it's like flickering. Hard to explain but it makes you feel like you are drunk. I had it on my Titan Blacks with G-Sync in Witcher 3 and a couple of other games, not nice !
I ran 670 SLI for a while with an ROG Swift, if anything it reduced the microstutter - not had any flickering issues (although it did occur early on during loading screens when it was 1-2 FPS but they fixed that).
Only real issue was a slight lack of oomph and VRAM, but 980Ti SLI fixed that :)
