Everything running fine until this morning..kids started moaning, 'dad it's got funny lines/flashing bits on monitor!'
Taken a look, at the time, it was still in Windows, although running in 4bit in lowest resolution. tried restarting, reseating card, different monitor with a different dvi cable.no change. (lines/flashing cursors were on display before windows booted up).
tried again this evening, now it wont display anything on either monitor.
safe to assume the card is at fault? the machine boots up fine, hdisk is ticking away as normal, just no display. havent got a spare card to try.
so if it is new card time, dont want to spend more than £100. what card will be compatible with my existing setup?
Ta.
Ta.
