Has my Cooler Died?
13 Oct 2011
Melbourne, Australia
I am running the spec in my sig, with a h50 cooling the CPU.
I was working on it fine this morning, with idle temps of 35C-37C ish. No move what-so-ever. I come back this afternoon, turn it on start internet browsing and realise the CPU temp has rose to 55C (over all cores).
After turning it off, i reboot into the bios and find myself just watching my CPU temps rise, starting at 35C, i turned off just before it hit 60C, creeping up at 1C every 5 or so seconds.
It was very scary.
I checked my hardware and the Fan on the H50 raditor is working and it sounds like the pump is working. I don't this a thermal paste issue
If it has broken, how can i tell? Im running of a motherboard header at the moment, worth trying straght from PSU? (may need a 3 pin to 4 pin adapter)
Sure something wasn't just loading the cpu a bit? Also the BIOS is not a 0% load thing so temps WILL climb as theres a load, plus power saving cpu optimisations etc. are not enabled as in Windows. Load it with IBT or prime etc.. to see where temps top out, if it keeps climbing to like 80-90C then obviously you have a problem, either the pump or seating etc. Would run it straight from the psu.
I don't know what had happened but i just switched the 3 pin pump cable to the PSU (instead of the 2nd header) and it now works perfect agian.
Thanks for the help anyway guys. :)
Good news, I've done the same... more than once.
with the Corsairs you can use a screwdriver as a listening device by putting the head onto the pump and place your ear near the end of the handle, that way you can easily isolate the noise and hear if the pump is going!
I just use the PSU as I have a dodgy Formula III Crosshair board on my other PC (the one which uses the H50), I had numerous problems going from rogue USB ports, daily auto CMOS clearing and fan headers not working. Though I know the PSU functions properly lol
