Hi
Was cleaning up the inside of my pc yesterday, i regularly periodlcally air dust the fans and clean out any fluff built inside in components etc.
Anyway i have done this many times without issue however yesterday i may have experienced my first component blow out. Stupidly i had pulled out the power cord from the psu while only turning it off at the psu and not at the wall.
There was no explosion but there was a small jolt (to me) and then a very slighy burning smell. thinking nothing of it at the time i continued, taking the leads out at the time and then carrying on the maintenance. It wasn't until i had put everything back together, leads etc. That my pc would not power on.
There was a distinct high pitch noise like a high frequency (possibly caused by the em field perhaps?? ) but nothing turning or moving (fans). The motherboard had no power of lights and none of the component had any juice. The psu itself was not moving as the base fan or the back fan within the psu was not even turning, only this high pitch noise.
I take it my psu has gone or the fuse or something within has blown? Worst thing is i have not got my receipt as my psu has a 3 year warranty. Just going to have to fork out another psu
Anyone comfirm this, would be much appreicated. Hope none of my other components are damaged ie mboard, gfx or worse
Thanks
Kyo
P.s would there been a chance that the psu had blown because i hooked too much stuff to it? I only got a single 1900xt , 3HD (2 Sata and 1 IDE) and a dvd burner. Would have thought a a 580W could handle that with ease. Just looking to see what make i should go for ? Hiper (i thought) is decent so i may go for the same thing again as i put it down to me being unlucky or careless? Any other psu suggestions would be greatful also.
Thanks
Kyo
Lots of people have got one and they say its silent and definitely worth the money
