Do you think perhaps AMD Fusion may be able to up the FPS?
i suppose it would be possible if the instruction sets for 3D calculations and full screen effects + multiple shader cores were all included on the one dye.
say 1nm tech arrives, i can quite easily see a very large amount of cores to deal with various things, including graphics.
imagine, a 1nm CPU with 8 General cores + 2 Graphic cores + 8 AA only cores +173 universal Shader cores, aswell as 256MB shared cache + 1 core to rule them all...
a 192 core CPU![]()
try 4 quad core xeons and i am sure you will get more than 2fps![]()
