If I have this wrong then please feel free to correct me.
As I understand it the X99 chipset has no memory controller, and it is instead on the CPU itself. Intel guarantees the FSB to 2133MHz and therefore even if the memory you buy is rated faster, the CPU may not be able to cope with what is in essence an overclock.
The DDR 4 is a 4 channel configuration so my question is whether the memory controller is divided into 4 'cores' in which some might be faster than others?
What if any processing / control does the motherboard do as it can't possibly be direct connect to the 2011 pins?
