Haswell Build ~£2k+
Hi @ All
Can you help me get started with some of the no-brainers on a new Haswell build.
Budget: Approx 2k but can go up to 2.5/3k if needed to stop having to cut any corners with the componants.
Purpose: Primarily gaming (but im starting Computer Games Tech Degree in Sept as well, so will be using for rendering etc)
Needed: Everything except mouse/KB and cooling; i will make seperate post in WC thread for what to get for a custom loop on CPU/GPU.
Notes: I like the look of 120/144hz monitors. Also, as im new to WC will bigger case be easier to work with?
Thanks
Hi @ All
Thanks
