Haswell-E on 2011-v3 mobo
10 Apr 2015
Hungerford, UK, Earth
regarding this statement from a website
Core i7 "Broadwell-E" will see Intel release its first consumer 10-core processor, besides 6-core and 8-core. The cheapest ($400-ish) part will likely be 6-core, the mid-tier part ($600-ish) will likely be 8-core, and the top-dog $1000 part 10-core. The TDP for these parts will continue to be rated at 140W. These chips will be supported by existing LGA2011v3 motherboards, with a firmware update, just like Core i7 "Ivy Bridge-E" were supported by existing LGA2011 motherboards of the time. Elsewhere on the roadmap, we see Core "Kaby Lake" desktop processors making an entry in Q4-2016
how would you upgade the bios, if your cpu doesn't support the motherboard. or is just for exising users, will there a 2011-v4 with native support?
I probably will go skylark anyway at some point, but thought Id ask just in case the pricing is viable
Manufacturers will likely release some new boards with a few new features and that are ready to go with broadwell straight away, whilst releasing bios updates for the haswell E boards so you will be able to plop a broadwell E cpu in when you want.
Like with my old sandybridge p67a board, i just needed to update the bios so i could stick an ivybridge cpu in there.
Don't trust that pricing ..... the have missed out the fact that Broadwell-E is going to have a FOUR cpu line up - two hex cores, one eight core and a ten core.
expect the two hex's to be differentiated by minor stock clock differences and more relevantly PCI-E lane count (like 5820k vs 5930k 28 vs 40 lanes)
The starting price for the lowliest hex WILL be around $400 (to put it a bit above the 6700k Skylake at $350) so to expect the Oct core CPU for $600 is wishful thinking indeed as I severely doubt with no current competition that Intel will consider a $100 dollar premium between the 28 lane hex to the 40 lane hex then another $100 premium from the 40 lane hex to the 40 lane Oct core CPU will be nearly enough... still Intel may surprise me.....
^ you are probably right but I live in hope that the 8 core Broadwell E cpu will be able to be had for a reasonable price (£400 or less) in a years time :p If AMD pull their finger out with Zen, it might happen!
