Hi,
I'm continuing to purchase the component parts for a new office computer build (CAD, no gaming), and now need to buy the CPU. My motherboard is a Gigabyte GA-Z97M-D3H. For software reasons my OS will be Windows 7, 32-Bit
I had originally decided to buy a Haswell Core i7-4790K processor. That was until I did some research and discovered that they are very prone to overheating and temperature spikes. It seems that many purchasers have had to return their i7-4790Ks for replacement. Defective chips seem worryingly common.
The problem is thought to be Intel's new polymer TIM failing to securely bond the IHS and Die together.
Intel started using the new polymer TIM instead of an Indium soldered joint on their 3rd and 4th generation Core i processors.
The new polymer TIM would only have been introduced for cost-cutting reasons - it is in no way superior to the previous (more expensive) Indium soldered joint.
I assume that the new TIM is some sort of thermally efficient plastic-based paste and I have yet to encounter any plastic that doesn't deteriorate with time and thermal cycling.
I thought I would avoid the potential problems of the Haswell Core i7-4790K processor and its polymer TIM interface by purchasing a 2nd Generation Core i Sandy Bridge processor instead. However, I'm surprised at how well the Sandy Bridge processors are holding their price. Maybe a lot of wise people have had similar thoughts, thereby keeping the prices high.
What does the team think and which Sandy Bridge processor would be the best one to go for?
