Haswell or Skylake for Pentium?
20 Nov 2009
Haarby, DENMARK
Me and my brother are building an extremely budget oriented system for my niece (his daughter). We initially bought a used core i3 4150 system with case, HDD etc, but somehow our postal service managed to loose a 8.2kg package and we are waiting for the postal sservices to give compensation for the lost pc.
Therefore we decided to buy all new stuff again but on a very very tight budget. We have decided on ram, case, psu, HDD, dvd Rom - as for graphics we are using a spare Gigabyte HD7850 2GB I have.
The choice we have is two of the following setups
ASROCK H81M VG4 & Intel Pentium G3258
or
ASROCK H110M-DGS & Intel Pentium G4400
Which option is the best way to go? We hope in a 3-4months time to upgrade the cpu to a core i3.
if you're upgrading to i3 i would get the skylake platform.... Don't bother with a g3258 until the i3. then you'll have the option to further upgrade should you wish to a i5 skylake/kabylake
on some motherboards you can use base clock overclocking on the g4400 and it can be very fast. not sure if the one you have picked would support that though.
Go skylake in Z170 board. Then upgrade to i3 which can OC in certain Z170 now. Done!!
That was also a thought we had briefly, but we couldn't make it within the tight budget... remembering that the postal service already lost an 8.2kg package containing a complete PC, and we are still awaiting compensation - money is very scarce :(
But the the end, we have now ordered this:
Cooler Master Elite 432 mATX
Enermax MaxPro EMP600AGT 600w (was cheaper than the 500w version)
Toshiba DT01ACA100 1TB, 3.5" SATA 6Gb/s 7200 rpm
ASRock H81M-VG4 2.0
Intel Pentium G3258 3.2GHz
G.Skill Ripjaws DDR3 8GB (2 x 4GB DIMM 240-pin) 1600 MHz / PC3-12800
LiteOn iHAS124 DVD±RW (±R DL) / DVD-RAM
Total of £229,38.
The "reasoning" behind choosing Haswell instead of Skylake was
1) better performance right now out the box with the G3258 OC'ed.
2) There's a larger used/2nd hand market out there with Haswell core i3/core i5 CPU's, meaning a cheaper upgrade path in the near future. Not a lot of people are selling their Skylake i3/i5.
I got hold of a core i5-3570K used for £45 and bought ASRock H61M-DGS - 2.0 new for £32 instead.
