Haswell to Skylake, would it be silly?
7 Oct 2003
Nottingham
Just ordered a shiny new Asus ROG Swift PG279Q and a GTX 1070 to replace a 1080p monitor and GTX 970. This got me thinking about a new Skylake Motherboard, i7 and DDR4 to replace my Haswell Z97 Motherboad, 4790K and DDR3.
Would this be complete madness or a sound investment as I won't upgrading again for a couple of years?
Thought as much, got that itch for shiny!!!
Out of interest in FPS what do you think the difference would be between the two on something like Doom?
Overclock your i7 4790k to 4.8 and get some ddr3 2400 cl10 ram won't be any faster or slower than the best Skylake though ;)
If you have the spare money why not. Although probably better ploughing all the funds into GPU for strictly gaming applications.
I'd keep the haswell i7, I'm starting to noticed bottlenecking slightly with my ivy i5 but that is only in BF 1 beta and GTA V, haven't played Witcher 3 yet but I reckon I'll see some there too. If you can get that i7 to 4.5ghz you'd be laughing.
Completely mad, especially at this point in time.
If you're going to do this, wait a couple of months for Z270 and Kaby Lake CPUs. Z270 brings Xpoint memory support, and also supports Coffee Lake and Cannon Lake CPUs, with Coffee Lake meant to have been confirmed to be 6-core.
It would be very silly to go for Z170 and Skylake at this point.
I don't think you would be better off upgrading the cpu. GPU upgrading would be more beneficial especially you are playing at such high refresh rate and g-sync.
yea totally worth it and while your at it ill give you £30 for you're 4790k as im doing you a favour...
no seriously stick with the 4790k for a while going to skylake from your current setup would be madness I don't think you would see any gains from it.
Doom is a terrible choice. For me;
980gtx and a AMD 8320 @ 3440x1440 - 60fps (near enough Ultra settings)
1080gtx and a 6700 @ 3440x1440 - 60fps (same settings as above)
Something like AC: Unity or Witcher 3, I only saw the difference thanks to my GPU. CPU too but not as big as you'd think.
So no, it's silly upgrading a perfectly fine CPU but I understand the need for 'shiny.
Xpoint memory support is hardly a good incentive to upgrade when it's not even going to be as fast as regular RAM is it?
Yeah looks like the first generation won't be, but seems quite likely to happen over a couple of generations of it (maybe by 2020?).
Although I don't know if it would be backwards compatible as it gets faster and more refined. So for now it would be wise to just view it as extremely fast SSDs.
It's still sensible to wait for Z270 for Coffee Lake and Cannon Lake support though. 6-core upgrade path, whereas Z170 is definitely stuck on 4.
