Hi guys, so after lots of research, I've come up with the computer which I intend to build imminently, and as there are far more qualified people here than I, I would appreciate if a few of you could look it over, and see if there's any design flaws or better decisions that could have been made which I have missed. I would also appreciate if any of the prices of the components could be better.
Here's the specs:
OCZ 4GB (2x2GB) DDR2 800Mhz/PC2-6400 Memory GOLD DUAL CHANNEL Unbuffered CL5(5-5-5-18) £33.00
PNY 8800GTS G92 512MB GDDR3 Dual DVI TV Out PCI-E Graphics Card £94.88
Intel Core 2 Quad Q6600 G0 Stepping (2.4GHz 1066MHz) Socket 775 L2 8MB Cache £149.95
ASUS P5QL SE iP43 Socket 775 6 channel audio ATX Motherboard £64.73
Antec 300 Three Hundred Case - No PSU £44.99
OCZ Stealth XStream 600W PSU - SLI Ready ATX2.2 12cm Fan £61.01
Seagate ST3500320AS 500GB Hard Drive SATA II 7200rpm *32MB Cache* - OEM £42.28
Arctic Cooling AC-FRZ-7P Freezer 7 Pro Socket 775 Processor Cooler £15.76
Samsung SM-2443NW 24" LCD Monitor 1920x1200, 20,000:1, 5ms, 300 cd/m2 £210.41
Thanks for reading!
Oh, I forgot to mention, I intend to do some overclocking, though not particularly to an extreme level, so please also mention if what I have found would work well enough for overclocking.
Here's the specs:
Thanks for reading!
