Have a problem with pc
Can you describe the problem in more detail? Does it happen randomly? Does it only happen when gaming? Do you ever get any error messages or just boom, restart?
Have you changed anything with the system lately?
When I press the on switch it doesn't even load up the boot up screen.
The PC just goes onto a cycle of off and on, the system fan spins and and the green leds ight up( which is normal), then it switchs off and then on, continue with the green leds and fan spinning, the goes off and then on again fan spins leds lights up and then off etc.... In a loop.
It just suddenly happened.
No I have not changed anything.
What are your system specs?
I'd make sure the backpanel is free of obstructions first off (like a clear CMOS button being pressed), check the front panel connectors in the case are alright, change the battery if it's easy.
If you have onboard graphics, you could try that.
One stick of RAM.
Different PSU.
You don't have any debug LEDs on the board?
1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core i5 4690K
Codename Haswell
Specification Intel(R) Core(TM) i5-4690K CPU @ 3.50GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
vendor MSI
model Z97-G45 GAMING (MS-7821)
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Module Manufacturer(ID) Corsair
splay adapter 0
ID 0x2120002
Name AMD Radeon R9 200 Series
Board Manufacturer ASUSTeK Computer Inc.
Codename Hawaii
Technology 28 nm
Memory size 4 GB
Memory type GDDR5
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1043)
Model ID 0x67B0 (0x046A)
Revision ID 0x0
Performance Level 0
Performance Level 1
Win32_VideoController AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController DriverVersion = 26.20.12001.7006
Win32_VideoController DriverDate = 06/12/2019
Monitor 0
Model DELL U2713HM (Dell Computer)
ID DEL407F
Serial 7JNY53CVAJ4L
Manufacturing Date Week 53, Year 2013
Size 27.2 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-81 kHz
Vertical Freq. Range 56-76 Hz
Max Pixel Clock 170 MHz
Gamma Factor 2.2
Software
