hyper make 520W psu's....![]()
You sir are on my christmas card list, thank you!I'd be looking at these:
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail - £91.99
MSI H61M-E33 Intel H61 (Socket 1155) DDR3 Motherboard **B3 REVISION** - £46.99
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - £30.98
The i3's HD2000 graphics is more than enough for outputting video's nad it also has a very low power usage! The motherboard has enough sata connectors for your HDD's and HDMI output. (only downside is that its out of stock atm, could shop around)
If you didn't want to spend £30 on RAM then single sticks can be bought for cheaper prices:
Corsair Value 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module - £15.98
Optional CPU cooler:
Scythe Shuriken Rev.B Quiet Low Profile CPU Cooler - £27.98
If you didn't like the noise from the intel one.
the DVD writer I have is too long
Any DVD-RW sata divre would be fine, whatever is cheapest, I went for the Samsung cause it was a well known brand and they were all the same price but it really doesn't matter.
