I pulled a usb stick from my pc and usb ports stopped working and ssd not booting, does this sound like the motherboard is now faulty, its a asus p8z77-v pro
i tried resetting the cmos but nothing so out of desperation i tried reinstalling windows and all looked good untill i tried to install the lan drivers and pc froze up restared the pc and tried again this time the drivers installed but windows fails to load so uninstalled drivers and tried again but exact saim thing happens, im thinking the mobo has had it
tried it, still having none of it, thought i had it sorted but as soon as i try to install the lan adator drivers the pc freezes up and no usb ports working
Sure it's code 31?? That usually points to network adapter.
Can you get into windows??
If you can reinstall network/chipset drivers, even if you have to use the older ones off your disc then update them.
Or try a restore point.
If you can't get into windows you may have to re-install windows.
yeah but the bios is different,im just thinking if it was corrupted in anyway it would error out when installing the drivers? idk but its free and worth a shot?
I have an old network card laying about somewhere but could not find it, i think even if it worked it would still bug me the motherboard was not working right, anyways new one in but i cant find the bloody tim
