have i dropped a clanger?
6 Dec 2006
Barnsley
Hi all I have purchased the below board and a 3570k cpu. I have now found out that this board only works on the new bios with newer i5 chips. Cpu due tomorrow .
My concern is I am moving from an older skt and have no way to upgrade the bios. Can anyone help?
Z68AP-D3 rev 2.0
Order something like the G440 (or one of the other cheap sandy pentiums) and use it to update the bios, then drop your 3570K in :)
Its new and sealed arm, was looking for a cheap upgrade and got that board no competitor price hinting. Thank you.. Know I can get 4.2 maybe a bit more once the board accepts the cpu. What's the chance of it been the newer bios,s with it been new?
if its gigabyte then you probably need a Celeron to flash to support later ivy bridge cpu
you can try it first or,return the motherboard n pick up a cheap z77 d3h board
Looks like I will have to try it, other option to borrow a cpu for a hour :p
Sure someone has a unused one knocking about.
Would the date of manufacturer be on the serial sticker?
