HAVE I GOT HT SETTINGS RIGHT ON NEW MOBO
5 May 2004
WEBCAM CAUSING ERROR BEEPS ON MSI MOBO HELP
HI ALL
i just got a skt 939 k8ngm2 fid mobo
everything was ok then yesterday when i switch it on i am getting 3 beeps
have tried everything and just happened to catch a post on google mentioning unistalling any usb things
well i have narrowed it down to my logitech usb webcam
when installed and plugged in i get 3 beeps on boot up
when unplugged just the normal 1 beep everything ok and boots fine
any ideas
Do you have boot on USB/Removable turned on in the BIOS boot priority somewheres?
Your sure the wiring is correct for the USB header (if it is not the back I/O panels)?
hi mate is te usb that legacy thing i have that disabled
usb ports used are the back ones
it is deffo the camera as i booted fine without it plugged in
also i ran prime 95 for a couple of hours with no probs at all so im sure mem is ok
i did hear htere is some kind of new beep code for ms and probs with usb but i cant find anything anywhere
