Spec
overclocked i7 930 2.8 @4.00ghz
Gigabyte GA-X58A-UD3r Motherboard
6Gb Corsair XMS Ram ddr3
64Gb Crucial sssd
Thermaltake 1500 w toughpower psu
Corsir Obsidian 800d case
h50 cpu watercooler
The physical setup is done and w7 64 bit is up and running i would like everyones opinion on the following
Replaced the supplied corsair fans with Sharkoon 1000rpms.
The rear fan that is attached to the h50 cooler is an intake fan and is attached to the cpu header. The cooler is attached to nb header just above gpu on the right. The top 3 fans are connected with the case intake fan from the power bay and is coonected to sys fan 1 header on the right just above sata ports.
Question 1
Is this correct and if not is there a better setup or more optimal configuration for cooling?
There are 4 hot swap sata bays on the right, have tried every configuration possible and my ssd would only be recognised by a seperate power and data lead and is currently resting on top of the hot swap bays - 3 other sata hard drives recognised instantly so am thinking theres a problem with the hw bay con on bay1.
Question 2
Now that its all setup should i try to rma the case as this would be a massive inconvenience - unless i install windows to one of the sata drives but then am left with a useless ssd - unless i leave it sat where its at.
Well thats the crux of the matter - main concern is the cooling and how i could improve it further if i want to install 2X gtx 285's in slot 1 - top and slot 3 bottom.
At present idle temps around 36 and load 57
The case is sat under a workbench at present and was sat on top when temps were 33 idle and 47 on load.
Question 3 Everything a sofar as the os is concerned is working crunching for seti etc - but when i switch to the overclocked settings seti seems to throw a fit and discard lots of gpu work units - even though the system as a whole is stable in every other respect. I have installed boinc and unified lunatics and have left it at stock cpu settings
Is there a way i can get to use the overclocked settings and configure boinc to not kick these work units.
Thanks all for your time, feel free to pass on your thoughts i can take criticism as long as it well help the build progress
64Gb Crucial sssd
h50 cpu watercooler
Question 1
Question 2
(I'm patenting MLI by the way
