- 6 Sep 2005
Please see below for what I need help with
Background info...
I've got a Dell 2408 (A00) which has a really puzzling problem...
When it's connected in DVI as soon as the computer is switched on it goes into power saving and won't come out of it, whether the machine is restarted, or Windows is loaded up - it just stays like it in DVI 1 and DVI 2.
I have tested it with a:
BFG 8800GTX
BFG 7300LE
Same problem with both...however using it with a 6800GT it works normally.
I've tried it on two machines with different cables and different motherboards (all Asus) but to no avail - power saving with 7 or 8 series, works with 6 series.
Today I have received a replacement monitor from Dell (again A00) and it does exactly the same thing.
To help me narrow it down:
Please post your specs:
Monitor revision
Type of Nvidia card
Type of Motherboard
Any problems encountered
I desperately need to try and track this problem down so any help is most appreciated.
I know a power save problem existed with ATI cards where it wouldn't wake up from power, the answer was to alter something on the graphics card. This is a different issue though, it goes into power save as soon as it detects a signal from the graphics card.
Many thanks
Background info...
BFG 8800GTX
BFG 7300LE
Monitor revision
Type of Nvidia card
Type of Motherboard
Many thanks
