Hi
I've been out of the loop for about 6 years due to kids. I need to update my pc...
Well GPU as a.minimum. I'm trying to decide if I can be bothered with a custom water-cooled loop anymore.
It's a faff changing things.
So considering getting an AIO.for a.cpu and leaving the gpu as it comes
Just wondered if you'd done this, or binned off water-cooled pc all.together..any regrets?
What made you make the decision to do it ?
Cheers
pretty much the same for me. Also the prices started to get a bit out of hand tooYes I moved away, only for one reason - there is no performance benefit. If water cooling made my CPU and GPU run 10 or 20% faster than air cooling I'd be happy, but those days are gone and water cooling has no performance benefit anymore
Do.you know the reason its hard to.get large rads and reservoirs at.the moment.?I gave up water-cooling (custom loop) a couple years ago but have started to find myself buying some Thermal Grizzley fitting and will buy there water-cooling when released for the 5090 Astral. I found myself missing the research and i much prefer the aesthetics although it seems difficult to buy things like 420mm Rads and even reservoirs right now
No idea at all to be honest, seems to be quite a few cases that will house the rads, can get some direct from manufacturer but will hold on for OCUK as prices seem reasonableDo.you know the reason its hard to.get large rads and reservoirs at.the moment.?
ZMT, acetal blocks and chromed fittings looks great.I think it depends quite a bit on mindset.
If you're water cooling and going the whole hard tubing route because a great looking PC gives you pointless internet likes/makes your partner/mum/sister wet... well, that's a hassle to maintain.
If you're water cooling for performance or noise purposes - ZMT wins. Ugly thick, super bendy black rubber tubing that you can just flex out of the way to mess with stuff. The blocks come off stuff, get pushed out of the way and aren't particularly harder to mess with than air or AIO.
Personally, very much in the second camp. Custom loop, when not a vanity project is fine.
So.two weeks in:I was just thinking to myself I wonder if I could be tempted back to custom loops and same this haha! I went from trying to build a monster to pretty simple AIO and suck it up…
Almost identical to the OP kids got in the way, but I do miss it having had 2x480mm and 2x 360mm rads waiting. Maybe I’ll convince myself soon![]()
So.two weeks in:
Love it..well almost.
Building it was a breeze,
Perhaps not as.much.fun. but certainly quicker and less moist.
Temps are good.
I'd forgotten how.easy it is.to move things around inside a case when you don't have to navigate tube and reservoirs.
Only slight irritation is that the aio (lian li galahand 2) pump noise. Its quiet, but.not as quiet as my previous set up. I guess this is the sacrifice for convenience. Fans are inaudible.
Now to go.through the pain of.getting rid of all my old stuff on the bay
Yep. I only notice it when thr rest of thr house is quiet. I'll have a play about over the next week and see if I can figure something out. Maybe some rubber washers where the coolers screwed to the mb. See if that makes a differenceThat's another reason why I would never switch to an AIO CPU water cooler from a custom set up. If you end up getting pump noise they is pretty much bugger all you can do about it. You can't decouple anything, loosen the mount, put the pump elsewhere in the case etc. Fair play if you can put up with pump vibration noise.
