- 20 Dec 2008
Thanks all for the input - already ordered.
Thank you very much, it gives me a good idea of what I should be aiming for with my price range. It would make sense to wait until the new games come out to get a new graphics card as well, so thank you all for the links.
Unless your planning on using your old system as well as your new system you may as well re use your old power supply. It's a corsair so it should have a five year warranty.
I haven't heard anything bad about XFX power supplies and they are a well known brand so you shouldn't have any problems if you decide to buy one.
- Dual Channel DDR3 memory technology
- 4 x DDR3 DIMM slots
- Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory
- Max. capacity of system memory: 32GB*
- Supports Intel® Extreme Memory Profile (XMP)
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 1066/1333/1600*/2133*(OC) DRAM, 32GB Max
- Supports 1GB/ 2GB/ 4GB/ 8GB DRAM size
- Supports Dual channel mode
A good case will come with filters.
You sure about that? which one is it? try reading some reviews of the case in question and they usually show the filters for the fans and on the front bezels of the the case.
