- 12 May 2011
- Southampton
I will be commuting to work by cycle due to an office move. It will be a 25 minute commute (so I'm allowing 35 minutes cycle time, plus 10 minutes faffing time at either end). Can someone help spec me a bike (or at least a type of bike).
I can see bikes can vary in price from £100 for a basic halfords bike to many thousands for what to me look pretty similar. A local cycle shop sells 'refurbished' second hand bikes from £80 to £200+. I am hoping to spend max £300 and I am getting a bit worried that some local shops ranges seem to be from £400 and up!
I think I'll want something "reasonably light" because I am fat and I remember liking my old Gripshift gears (if they're still a thing). I'll be commuting on a mix of roads and paved off-road (through a park) but I don't want to fall over if it's a bit wet or I go on a little bit of grass so I suppose that rules out racing/road bikes (which I assume are the lightest).
Being a shorty (5ft 9) I have googled that I'll need a medium frame - 55cm. What determines what wheel sizes I need?
Any brands to avoid?
Is it worth buying a decent saddle?
Can anyone recommend a helment for someone with a higher than average of a) falling off and b) being flattened by a bus?
Any other accessories (I'm tempted to get a speed/mile computer)
