Hello all, i'm asking you here for advices because i recently bought a router from TrendNet (TW100-BRF114U) which works fine. Everything works, DHCP server gives the right IP's and i can access the net on both computers, but sometimes at random times the router stops giving the right ip adresses and i end up losing connectivity to the net. If i take out the power cable and put it back after a few sec the routers gives the right ip's again. I looked at the config menu i can access and everything looks fine, i just upgraded the firmware to see if there is any changes. Do you guys have any clues ? thanks in advance
