- 28 Oct 2006
- stoke on trent\bromsgrove
hi folks
i am just having this little lot built up now & i will be using my sig hardware in it for a few months or a bit longer, but i am thinking i might upgrade the mobo & the cpu to the new intel ones if they are better then the i7 920 ( 1366 ) socket one i have now running at 3.60.
however i might keep my gpu zotac 570 amp as it runs all my games now nice & smooth.
here is the WC kit what is being built =
YOUR BASKET
1 x Corsair Obsidian 800D (6GB/s) Full Tower Case - Black £239.99
1 x XSPC RayStorm CPU WaterBlock (Intel) Copper £96.98
1 x Hardware Labs Black ICE Radiator SR1 360 £69.98
1 x Asus Xonar DX 7.1 PCI-Express Sound Card £59.99
1 x XSPC D5 Vario (Body + Screwring) £56.99
1 x EK-BAY SPIN Reservoir CSQ - Acetal £46.99
1 x Scythe Kaze Master Ace 5.25inch Fan Controller - Black £33.98
1 x Mayhems Ice Dragon Nano Fluid 1L £23.99
1 x EK-DDC X-TOP CSQ - Plexi £16.98
1 x Sony Optiarc AD-7280S 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
3 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £14.98 (£44.94)
1 x NZXT 24-Pin ATX White Sleeved 25cm Extension Cable - CB-24P (BWW) £10.99
2 x NZXT 6 Pin PCI-E Black Sleeved 25cm Extension Cable White (CBW-6V-45) £8.99 (£17.98)
2 x XSPC 7/16" ID (16/11mm) High Flex Hose - Clear £2.99 (£5.98)
8 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£23.92)
Total : £782.34 (includes shipping : £14.75).
& my system parts what i have now are =
i7 920 @ 3.60, asus p6t oc-etd, 12GB corsair xms3, zotac gtx 570 amp.
my top price would be about £500 too 1k for the new mobo & cpu etc.
YOUR BASKET
