I will try and keep this as short as possible. Before I go any further, I did search this forum and found lots of bits of helpful information, but nothing that fully answered my questions, hence the new thread.
I play rocket league and overwatch. I've been using a borrowed Samsung 27" with a VA panel since my old monitor broke down but my friend needed it back.
Decided that it's time I join 144hz, everyone raves how much better it is. After very little research (I didn't realise what a minefield it was at this time), i bought a BenQ 2411z. I based this purchase on the fact that the majority of Overwatch pros use this or the 2430. When the monitor arrived, my jaw nearly hit the floor at how god awful the colours were. There was also a stuck pixel which was very annoying. No amount of configuring could get the colours, no matter how many other peoples settings I tried, i wasn't satisfied and I returned it.
I started to research and at this point realised what an absolute minefield monitors currently are. I spoke to someone about monitors from reddit and he advised that if I wanted 144hz TN panel and was willing to spend a bit more, then I should get the Acer Predator XB241H. Now don't get me wrong, the colours out the box are so much better than the BenQ, hands down, however compared to the old Samsung VA panel I was using, the colours just don't compare.
This brings me to the point I am currently at with research. It seems that if you want good colours, IPS is the only way to go. Do I return this and get a 27" IPS 144hz panel? I've done research and there seems to be so many issues with BLB and glow on the only 2 monitors that meet this criteria for gaming which is the Asus and the Acer predator. £700 is a lot to drop on a monitor that I may need to send back several times to get a decent one.
Maybe I should get a 60hz, cheap IPS panel and wait for the technology to come on a bit?
Up until around a fortnight ago, I had no idea on all the different monitor panels etc and this has been an absolute eye opener for me.
Whatever information/advice people have to offer, I am all ears. If you have monitor recommendations then great, it would really be appreciated.
If you recommend a budget 60hz IPS 27", what would you recommend? If you recommend a 27" IPS, please also tell me what you would recommend.
Thank you in advance for any replies.
