having an issue with javascript and php ??
6 Jan 2006
Newcastle
Hi Im trying to put the cloudflare logo on the footer of my wordpress blog but im failing miserably can anyone shed some light on it ?
Code:
<?php
 * The template for displaying the footer.
 * Contains the closing of the id=main div and all content
 * after.  Calls sidebar-footer.php for bottom widgets.
 * @package WordPress
 * @subpackage Twenty_Ten
 * @since Twenty Ten 1.0
	</div><!-- #main -->
	<div id="footer" role="contentinfo">
		<div id="colophon">
<?php
	/* A sidebar in the footer? Yep. You can can customize
	 * your footer with four columns of widgets.
	get_sidebar( 'footer' );
			<div id="site-info">
echo"<script type='text/javascript' src='http://ajax.cloudflare.com/cdn-cgi/scripts/cf_status.js'></script>\n";
echo"<a href='http://www.cloudflare.com' style='display:block;position:relative;width:0px;height:0px;'>;
<img src='http://ajax.cloudflare.com/cdn-cgi/images/seal/standard/0x0.png' style='position:absolute;clip:rect(0px,0px,0px,0px);border:0;' onload='try{window.__CF.checkStatus(this)}catch(e){}' /></a>";
			</div><!-- #site-info -->
			<div id="site-generator">
				<?php do_action( 'twentyten_credits' ); ?>
				<a href="<?php echo esc_url( __( 'http://wordpress.org/', 'twentyten' ) ); ?>" title="<?php esc_attr_e( 'Semantic Personal Publishing Platform', 'twentyten' ); ?>" rel="generator"><?php printf( __( 'Proudly powered by %s.', 'twentyten' ), 'WordPress' ); ?></a>
			</div><!-- #site-generator -->
		</div><!-- #colophon -->
	</div><!-- #footer -->
</div><!-- #wrapper -->
<?php
	/* Always have wp_footer() just before the closing </body>
	 * tag of your theme, or you will break many plugins, which
	 * generally use this hook to reference JavaScript files.
	wp_footer();
</body>
</html>
You don't need to echo it because you're not inside php tags.
Change:
Code:
to:
Code:
Hi,
I actually work for CloudFlare. Did you figure this out yet? One thing I did notice a problem with in the actual CloudFlare script is that you're missing the px values (silly bug on our end). If you login to your CloudFlare account & then go to the 'Web Badges' link, you'll end up getting the right code.
Change:
Code:
to:
Code:
Hi that's stopped the random code "echo" appearing however nothing is appearing
Hi,
tried that and it still dosent work
Code:
<script type='text/javascript' src='http://ajax.cloudflare.com/cdn-cgi/scripts/cf_status.js'></script><a href='http://www.cloudflare.com' style='display:block;position:relative;width:0px;height:0px;'><img src='http://ajax.cloudflare.com/cdn-cgi/images/seal/standard/0x0.png' style='position:absolute;clip:rect(0px,0px,0px,0px);border:0;' onload='try{window.__CF.checkStatus(this)}catch(e){}' /></a>
This details the fix
http://support.cloudflare.com/kb/tr...re-web-badge-showing-when-i-put-it-on-my-site
Code:
<script type='text/javascript' src='http://ajax.cloudflare.com/cdn-cgi/scripts/cf_status.js'></script><a href='http://www.cloudflare.com' style='display:block;position:relative;width:180px;height:32px;'><img src='http://ajax.cloudflare.com/cdn-cgi/images/seal/standard/180x32.png' style='position:absolute;clip:rect(0px,180px,32px,0px);border:0;' onload='try{window.__CF.checkStatus(this)}catch(e){}' /></a>
