OK I spoke to soon. It didn't finish...
It just got further than previously and I thought it was fixed. So this was the error log. Very odd as it talks about steam and C: drive. But I was copying D: to F: Nothing to do with C:???
Help please.
(Gathering writer metadata...)
(Waiting for the asynchronous operation to finish...)
Initialize writer metadata ...
- Get exclude files
- Enumerate components
- Get file list descriptors
- Get database descriptors
- Get log descriptors
- Get exclude files
- Get exclude files
- Get exclude files
- Get exclude files
- Get exclude files
- Get exclude files
- Get exclude files
Discover directly excluded components ...
- Excluding writer '' since it has no selected components for restore.
- Excluding writer 'Shadow Copy Optimization Writer' since it has no selected components for restore.
- Excluding writer 'MSSearch Service Writer' since it has no selected components for restore.
Discover components that reside outside the shadow set ...
- Component '\TasksStore' from writer 'Task Scheduler Writer' is excluded from backup (it requires C:\ in the shadow set)
- Component '\WriterMetadataStore' from writer 'VSS Metadata Store Writer' is excluded from backup (it requires C:\ in the shadow set)
- Component '\PerformanceCounters' from writer 'Performance Counters Writer' is excluded from backup (it requires C:\ in the shadow set)
- Component '\Registry' from writer 'Registry Writer' is excluded from backup (it requires C:\ in the shadow set)
- Component '\COM+ REGDB' from writer 'COM+ REGDB Writer' is excluded from backup (it requires C:\ in the shadow set)
- Component '\WMI' from writer 'WMI Writer' is excluded from backup (it requires C:\ in the shadow set)
Discover all excluded components ...
Discover excluded writers ...
- The writer 'Task Scheduler Writer' is now entirely excluded from the backup:
(it does not contain any components that can be potentially included in the backup)
- The writer 'VSS Metadata Store Writer' is now entirely excluded from the backup:
- The writer 'Performance Counters Writer' is now entirely excluded from the backup:
- The writer 'Registry Writer' is now entirely excluded from the backup:
- The writer 'COM+ REGDB Writer' is now entirely excluded from the backup:
- The writer 'WMI Writer' is now entirely excluded from the backup:
Discover explicitly included components ...
Verifying explicitly specified writers/components ...
Select explicitly included components ...
Creating shadow set {acf86da0-11fb-4c4b-90f7-c1f75e6433df} ...
- Adding volume \\?\Volume{00074f2e-0000-0000-0000-100000000000}\ [D:\] to the shadow set...
Preparing for backup ...
Creating the shadow (DoSnapshotSet) ...
Shadow copy set succesfully created.
Saving the backup components document ...
List of created shadow copies:
Querying all shadow copies with the SnapshotSetID {acf86da0-11fb-4c4b-90f7-c1f75e6433df} ...
* SNAPSHOT ID = {0f165ee5-b1bc-40f6-9d78-0bf95b6df3a1} ...
- Shadow copy Set: {acf86da0-11fb-4c4b-90f7-c1f75e6433df}
- Original count of shadow copies = 1
- Original Volume name: \\?\Volume{00074f2e-0000-0000-0000-100000000000}\ [D:\]
- Creation Time: 29/08/2017 23:30:44
- Shadow copy device name: \\?\GLOBALROOT\Device\HarddiskVolumeShadowCopy13
- Originating machine: DESKTOP-KTJ27GS
- Service machine: DESKTOP-KTJ27GS
- Not Exposed
- Provider id: {b5946137-7b9f-4925-af80-51abd60b20d5}
- Attributes: Auto_Release Differential
Windows Events
Date 30/08/2017 03:08:33
Type Error
Event 33
Source SideBySide
Activation context generation failed for "c:\program files (x86)\steam\steamapps\common\the dig\testapp.exe". Dependent Assembly Microsoft.VC80.DebugCRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.762" could not be found. Please use sxstrace.exe for detailed diagnosis.
