- 24 Jul 2005
I just received my Ultima Rampage 280 OC system from Overclockers today.
I am having massive trouble with it whenever it launches a game. It seems to crash the entire system into a reboot within minutes of play if I am lucky. I'd assume that something or many things are overheating. I tried Oblivion and Neverwinter Nights 2 so far. Both of them are hardly the BEST graphical games out so I don't see why they would cause this overheat, or does any game when using high graphics settings cause an overheat?
The OS is Vista Home Premium 64bit. Overclockers for some reason sent me the system overclocked, which I didn't want. They clocked the quad cores from 3ghz to 3.6ghz. I can't even tell if they have overclocked the memory etc. because I don't have enough experience with overclocking. I went in the BIOS and changed some of the stuff from manual to AUTO which seems to have brought the CPU cores back to 3.1ghz.
The Geforce 280 card in this machine seems to get very hot, I haven't run a temperature software to gauge exactly how hot yet, but if I open the case soon after one of these crashes and touch it, it is scorching.
I also purchased a Xonar D2X sound card which fits into a PCI-E slot. the only free slot was direcetly beneath the graphics card and the space between the two is literally 1-2mm. Could this close proximity be causing the graphics card to overheat to the point of crashing?
The case is a Coolermaster RC1000 and there seems to be enough fans going on in there.
I guess the weather is pretty hot and humid too atm, but surely if I buy a PC for £2240, it should be able to withstand a bit of warm weather?
