I'm having problems with a system upgrade which crashes with 'Blue Screen' when running intensive stuff like the game Crysis.
Using the BSOD info I did some research on Google which suggested faulty memory and that I run MemTest.
My memory is 2x1GB Corsair XMS2 800 CAS 5.
So I did and found that Test 7 (Random Number Sequence) mostly fails.
So I then tried to identify the faulty stick by running MemTest with each stick in DIMM1 in turn. All tests passed.
So thinking it may be the socket that is the problem, I ran MemTest with each stick in DIMM3 in turn. All tests passed.
So I have the situation that either stick, in either DIMM socket will pass MemTest, but the two together will fail.
So I thought it may be voltage.
So checking using AbitEQ and Everest, I find that the DDR2 voltage is 1.94V whether I have 1 or 2 sticks. This is correct for the RAM which is nominally 1.9V.
This morning I was all set to buy new RAM but now I'm not so sure the RAM is faulty.
Any ideas what to try next?
BTW - RAM is being ran as SPD settings and stock frequency.
Cheers,
Nigel
Cheers,
Nigel
