- 28 Nov 2012
- Merseyside
I've just got a CM Storm Scout 2 (came with a fan) and I also picked an extra Coolermaster Sickleflow from work (I work for an undisclosed consumer electronics retailer). Seem to be good fans overall.
Unfortunately.. my motherboard only has space for one case fan due to insufficient connectors and I don't really want to go through molex because it they can get a little on the noisy side, I'm upgrading my mobo soon but the number of connections for fans will still be insufficient so I need to figure out an alternative as I plan to use a total of 5 (maybe 6) case fans.
So.. best ways?
I've been reading about fan controllers... what are they like, and how do they work? Would I just connect my fan controller to a 3pin output on my motherboard and then connect my fans to 3pin outputs on the fan controller? If so... wouldn't some power be lost because of multiple fans going off the one connector?
Any help is much appreciated, if you could be as detailed and informative as possible that would be a great help.
So.. best ways?
