Having problems setting up RAID on P5B-Deluxe, Plz Help
26 Oct 2006
London
hey guys, i'm having trouble setting up raid on my newly build computer.
As required, i went to BIOS and went to ide configuration and set the sata configuration to "enhanced". I then restarted and pressed ctrl-i for the raid setup and created a raid array for my hardrives. I then inserted the asus support disc and inserted a floppy disc, pressed a, and then made an intel raid driver floppy disc.
I restarted the computer, swapped the cd with the windows xp disc, pressed f6, but this is where i'm having the problem.
When i press s and choose the intel raid driver and then click on enter, i get an error message saying:
"File iaStor caused an unexpected error (4113) at line 2113"
I tried to download the latest raid driver from intel (using my sisters computer), but i try to extract the files to floppy disc, but i get this error message saying invalid disc volume, so i'm completely lost here.
Both of my hardrives are connected to two sata connectors and not in the jmicron sata connector.
I would grately appreciate if ANYONE can help me out here as this is giving me such a headache
it ok, all sorted. Think it was the floppy drive that was acting dodgy, i just reinserted the floppy disk in and out abt 10 times and eventually it managed to work :)
